guages on cluster won't work
Old Jun 2, 2011 | 09:31 AM
widowmaker's Avatar
Default guages on cluster won't work
i have a 2000 accord lx and i just replaced the cluster lights to led. now the lights are changed and work but the speedometer or the tach and temp and fuel guage in the cluster dont work nor the digital odometer or pwr windows. i checked the fuses didnt see nothing blown and checked the plugs to make sure there pluged in and checked and replaced them nothing. i took a tester to them the fuses that fun the power windows under the the hood work but the fuses on the passenger side that run the windows dont get power same with the cluster but the lights are working on then. im sooo confused on not sure if its a ground or what any help plzzz?
Old Jun 2, 2011 | 09:46 AM
Take out Led's put back in originals and see if it works..if not..you screwed up something..
Old Jun 2, 2011 | 10:00 AM
widowmaker's Avatar
did nothing
Old Jun 2, 2011 | 02:42 PM
deserthonda's Avatar
chk fuse # 13 .. 7.5 amps ,, passenger under dash fuse box ,,, let us know if that's the fix
Old Jun 2, 2011 | 04:21 PM
widowmaker's Avatar
Default its still good
i changed the fuse nothe tested the fuse holes both sides no power
natwood68
Feb 24, 2014 12:16 PM
njmodi
May 29, 2008 01:11 PM
Calidude87
May 22, 2008 03:27 PM
PJ_STYLES_95AccordEx
Aug 21, 2006 11:45 PM
GLrunner13
Jul 22, 2006 04:28 PM
