Handbrake Adjustment
Old Nov 17, 2012 | 03:07 PM
Silver6gen's Avatar
Didn't notice any thing wrong with the caliper today.
Things I inspected:
- Pins, they were lubed and the boots were still in good condition
- pads, the inner pad was a little unevenly worn so I swapped them (put the inner on the out and vise versa)
- Checked the spring - was ok
- Checked the cable - was also OK
- applied the brake on different levels and used a torque wrench to test the amount needed to move the tires. Both sides were within 2 ft lbs.
- noticed nothing wrong with the rotor or bearing....
- I also screwed in the piston a half turn to see if it just needed to be reset
So I am kind of at a loss, I will see if the pad swap made the difference. At least I know the caliper isn't frozen.
Old Nov 18, 2012 | 07:17 AM
Humm....these drive you carzy. Let us know how it comes out.
Old Nov 18, 2012 | 07:55 PM
How'd you swap inner & outer? Isn't there metal tabs on the inner to make a squeeking sound when they wear out?
abhijitgp
Aug 15, 2011 04:20 PM
jasonfridlund
Jun 14, 2009 11:32 PM
uk.accord
Oct 4, 2008 12:15 PM
uk.accord
Sep 22, 2008 01:52 PM
jo3lam
Jun 27, 2007 10:54 PM
