hard shift from 1st to 2nd gears in accord 98
Old Sep 29, 2013 | 12:39 AM
Rilex's Avatar
Default hard shift from 1st to 2nd gears in accord 98
greetings to you all, my accord shift hard from 1st to 2nd gears only while rpm revs to 4000 then back to 2000. But from 3rd to 4th it shift smoothly and drives very well on the highway. All the solonoids seems all ok, we changed the transmission fliuds. Could it be the torque converter causing this problems! On the highway say 60mph the rpm stays stead at 2000 to 2500 which is normal. All sparks plugs are new. Can also bad injector nozzle be respnosible for this jerky shift? Mileage is 207000
Old Sep 29, 2013 | 02:19 AM
Honda-Master's Avatar
any codes?? worse when cold??
Old Sep 29, 2013 | 08:43 AM
Rilex's Avatar
the first mechanic shop I went to gave me code p0702. The second shop gave code p1491, but says no transmission problem exist. What do you suggest might be the problem? Even if the gear has problem it might not necessary means replacing it from my own point of view, probably a rebuilt since is only affecting 1st and 2nd gear only. Thanks
letsclique
Jun 18, 2016 04:29 PM
gigem891
Apr 4, 2014 08:46 PM
64Cheyenne
Feb 9, 2013 05:42 PM
triple$accord
Apr 15, 2008 06:54 PM
cache
Apr 16, 2006 04:43 PM
