head gasket?
Old Mar 21, 2009 | 08:01 PM
jackfast's Avatar
Default head gasket?
i have been struggling with overheating and coolant loss.
i just replaced the radiator, and am still loosing coolant, although there are no visible signs.
some white smoke out tailpipe, but not alot.
no water visible in the oil.
how do i know for sure if it is the head gasket?
if it is, how big a job is it cost wise and hours.
is it posible to do on my own, with a manual and a friend who has some experience?
if so, are there any links for "how to's"?
i am not willing to give up on my car yet...
Old Mar 21, 2009 | 09:16 PM
finch13's Avatar
A leak down test would let you know you're losing cylinder pressure.
As far as cost, I've heard of them range from $400 to $1200 to do, and that $1200 is from a Honda dealer.
It can be a DIY job, but you would need to bring the head somewhere to have it milled flat.
Old Mar 22, 2009 | 03:04 PM
jackfast's Avatar
would i necessarily see water in the oil with a blown head gasket?
Old Mar 23, 2009 | 07:30 AM
Common, but not always. If the headgasket leaks in a location that puts combustion gases into the cooling system, then you see boil-over problems with your antifreeze.
A leak-down test can tell you where it's leaking into. Pressurize the combustion chamber & listen for where it goes.
thunder_x
Jul 9, 2007 11:57 AM
dodins
Mar 18, 2007 08:10 PM
samuel_c038
Mar 10, 2007 06:50 PM
noboundaries6289
Feb 21, 2007 10:30 PM
corr04
Oct 31, 2006 10:02 AM
