Head light burns out constantly... please help.
Old Jul 6, 2008 | 08:16 PM
rtmobile96's Avatar
Default Head light burns out constantly... please help.
So my girls 01' Accord is burning out the passenger side head light about every two months. I don't know whats wrong and I've never seen this before. I've changed plenty of headlights and I know not to touch them. The first time I figured maybe I did, but I'm on the forth bulb now and I've been overly carefull not to touch the last three. Any ideas?
Old Jul 6, 2008 | 11:22 PM
Default RE: Head light burns out constantly... please help.
Sometimes a bad alternator puts out voltage spikes. You might see a voltmeter jumping around when the engines running. Or you might need an oscilloscope to see it.
Another idea? Check the little rubber bumper stops where the hood closes. If theyre too high, it might hammer the headlights whenever you close the hood?
Old Jul 6, 2008 | 11:32 PM
rtmobile96's Avatar
If the alternator was going bad wouldn't I see other issues with the car? And as far as the bumper stops go, I'll have to look for them to be honest. I'm not 100% what you're talking about. I know my 96' inside and out, I'm still getting to know my girls 01'.
Old Jul 6, 2008 | 11:41 PM
rtmobile96's Avatar
So about my last post, I'm a moron. I just looked at the car and your probably talking about the bumper stops just above the head lights. Yeah I took bumper literally as in some sort of a front bumper stop. My bad. I checked them and they look like they are just right. A little play in the hood when it's shut but no sag either.
Oh, and for what ever reason, I get a "This page can not be displayed" erroreverytime I try to click into this post. I have to use the drop down and go to the last reply in order to get in. Hopefully not everyone is having that problem cause I need help. Even the cost of the regular average headlight is getting expensive. The first two bulbs where the good $20 a pop bulbs. Now it's $10 everytime.
Old Jul 6, 2008 | 11:55 PM
Electrical spikes can be flaky. Many things have their own voltage regulation, for example the ECU. Not headlight bulbs...
And yeah I still have trouble displaying some threads & posting to some too.
https://www.hondaaccordforum.com/Sti..._128656/tm.htm
Old Jul 7, 2008 | 12:12 PM
If you hit the tiny icon to the left of your thread title you can open the message.
Regarding the light burnouts, I would check the connector carefully. A loose connector, might cause rapid on/off application of voltage to the bulb. Look for evidence of arcing on the bulb contacts.
As suggested vibration could also damage the filament. Is the headlight assembly completely secure? I've seen cars approaching me at night w/ the headlight noticably wobbling. It might help to drive towards someone at night to see if any movmentis noticeable.
Old Jul 9, 2008 | 11:27 PM
rtmobile96's Avatar
I'll check the headlamp assembly to make sure it's tight. Also thinking about it, a surge could be possible I guess. Each time it's blown, I've noticed that the small coil inside the bulb is totally blown. In most cases I've seen when a headlight just burns out, that little coil just kind of seperates. With these blow outs, the entire coil is gone. I'll have to check the connections.
haywyre
Feb 4, 2013 04:51 AM
sam786
Feb 12, 2010 09:11 PM
ka$htharipper
Sep 30, 2007 12:08 PM
girlcrazy_4
Sep 26, 2007 07:00 PM
Pat88
Jun 7, 2007 02:10 PM
