headlights wont come on, 2000 accord
Old Feb 13, 2006 | 06:36 PM
tazkick
Default headlights wont come on, 2000 accord
A friends headlights have been blinking on and off at random for a couple days and then last night wouldn't come on at all. However the brights will work fine. It doesn't sound like a bulb or a fuse problem. Any suggestions on what it could be?
Old Feb 13, 2006 | 07:32 PM
lightshow's Avatar
Default RE: headlights wont come on, 2000 accord
mmm actually does kinda sound like a bulb problem. maybe its the switch though too or a fuse. does he have those cheap *** aftermarket bulbs in there. if he does then its prolly the bulbs. the sylvanias that are in the high beams will run forever.
Old Feb 13, 2006 | 10:20 PM
AgentofDarkness's Avatar
I dunno how it could be a bulb or a fuse. If the fuse was bad, it would be blown and nothing would work. If its a bulb, you could swap the bulb out and see what happens. Maybe its a switch
Old Feb 16, 2006 | 04:30 AM
EMEX's Avatar
simple, if the bulbs have to much wattage (like more than specifed in the manual to use) then the lights will burn out faster. not only that they can also burn the wiring to the bulbs. fuse would probably the last thing to check. but if your friend is using higher wattage bulbs then required, take them out immidiatly. my friend had that problem on his car; put in high wattage bulbs that burned up in a week or two and also burned his wiring.
l0kz
Feb 18, 2012 04:45 AM
outlaw423
Dec 31, 2011 06:21 PM
eddie sands
Feb 28, 2011 06:55 AM
nickattack21
Aug 7, 2010 10:23 AM
nrangerfan
May 20, 2005 01:57 AM
