Heat problems
Old Nov 15, 2010 | 07:38 PM
Cessna172's Avatar
Default Heat problems
Hello, I have a 98 accord, and the heat isnt working right. Sometimes it blows out hot air sometimes it doesn't. sometimes it starts out warm but than goes cold. Sometimes it will only work when the blower is either on off 1 or 2, above that it gets cold. The cable out to the valve is connected and moving, hot fluid going into heater core and coming out. I am thinking it is something to do with the mixing? any help would be great, need the heat for my 2 year old daughter to stay warm.
Old Nov 15, 2010 | 11:16 PM
Does the engine coolant temperature gauge in the cluster stay at the normal temperature? Or does it drop when you accelerate?
Old Nov 16, 2010 | 08:28 AM
First I'd check for air in the cooling system. Honda's don't like to have any air in there, and the heat going hot & cold can come from that.
Here's the heater box, it's kinda centered in the dashboard, so you'll have to remove some panels to see this stuff. Maybe remove the glovebox & the panel below the glovebox.
#6 is the air-mix motor. It seems to be working 'cause it's driving the cable (#9). But that air-mix motor is also supposed to move some air-mix doors inside the heater box (not really shown in the picture). Maybe you can move the temperature control & listen whether you can hear the doors moving??
skijour
Aug 15, 2012 08:31 PM
elemorie
Nov 30, 2011 11:14 AM
Cessna172
Nov 5, 2010 01:22 PM
vince_carnovale
Jul 18, 2008 07:38 PM
KimberlyC
Apr 16, 2006 11:51 AM
