heater blower relay
Old Apr 1, 2008 | 04:42 PM
kool77
Default heater blower relay
I have a 2003 Accord LX. The blower motor suddenly stopped working. I checked the fuses, and they were good. I got no voltage reading on the harness to the blower under th glove box. Any suggestions? Thanks
Old Apr 1, 2008 | 06:41 PM
Default RE: heater blower relay
Did you check the fuses in the engine fuse box?
The blower motor relay or the heater fan switch are the next electrical component to check. The relay is in the dash fuse box for a 95, but I am not sure where it is at for an 03 accord. If there is a relay that is the identical, then swap them and see if the blower works. If it does, then the problem is solved - get a new relay. You can jump the proper terminals, but I do not know which ones to jump.
Honda Man For Life
Apr 9, 2012 09:38 AM
CougarMark67XR7
Apr 5, 2009 04:15 PM
MSA
Nov 14, 2008 01:26 PM
SM90Exi
Nov 13, 2008 09:42 PM
billgrego
Sep 27, 2007 11:37 PM
