Heater not getting hot 1997 honda accord
Old Dec 12, 2009 | 08:49 PM
ecomajor's Avatar
Default Heater not getting hot 1997 honda accord
I have a 4 cylinder 4 door accord dx value package. Does anyone have a good picture or a good description of how to access the thermostat. My heat does not get very hot (it gets a little warm) but not warm enough to counter 15 degree weather so I am pretty certain I need to replace or fix my thermostat, but I cant figure out how to access it. Is it accessible from the top of the car or do I need to go under neath. Are there any other possibilities if my heat is not really hot?
Old Dec 14, 2009 | 10:05 AM
It's kinda below the throttle body.
Follow the LOWER radiator hose - over the transmission & back towards the firewall. Reach the thermostat from above, but you probably have to remove the rubber air intake duct.
Old Dec 14, 2009 | 11:19 AM
deserthonda's Avatar
also, chk to make sure that heater valve is working properly
Old Dec 14, 2009 | 11:21 AM
Talking Questions, Questions-Questions...
Good answer and Good Pictures as usual James
Attached Thumbnails Heater not getting hot 1997 honda accord-img_xmastree.jpg
Old Dec 15, 2009 | 04:12 AM
19Accord97
Its not to bad to get to. You should most def. remove the intake for easy access. Also note there is a bolt that is very hard to see (#29). I didn't see it and ended up causing a major headache for myself.
Anyways, make sure to ONLY use a Honda thermostat and that the opening circle thing is at the top when you install the thermo.
PJ_STYLES_95AccordEx
Mar 23, 2015 09:59 PM
mehoff636
Sep 11, 2011 08:53 AM
dsgammo
Nov 12, 2008 07:59 AM
jrcastro
Jun 24, 2006 12:45 AM
soldierforchrist2
Dec 4, 2005 11:34 PM
