Heating and Cooling system does not work at all
Old Jan 4, 2012 | 09:28 PM
rjr8088's Avatar
Angry Heating and Cooling system does not work at all
2006 Accord EXL I4 : Put in aftermarker radio. Had to use the harness 70-7864-DZ to convert dual zone to single. After wiring it up per instructions, when I turned on switch fan came on and had no controls. Immediately turned off. Removed the harness and plugged the DZ plugs back into head unit. Radio works fine but all HVAC is dead. Can anybody give me some pointers?
Old Feb 18, 2012 | 11:39 AM
There are two connectors shown for the Audio-HVAC Display Panel Inputs and Outputs in the Honda Shop Manual. All the HVAC appears to flow through the 22 pin connector (upper LH position as you look at unit). Are you sure you joined this connection?
In any case, suggest getting a shop manual. Check ebay seller automanualsource for a $21.99 downloaded Honda shop manual. The HVAC system manual has diagnostic procedures and how to download DTC's for the system.
stavrich
Apr 18, 2015 05:59 AM
SLIPKANOT
Feb 10, 2013 07:47 AM
rajateli
Jan 5, 2013 07:49 AM
mandycae
Sep 5, 2012 06:35 PM
CDJDM07
Aug 24, 2011 09:51 AM
