Heli Coils for Valve Cover bolts on a 1994 Honda Accord with VTEC engine
Old Oct 6, 2008 | 12:17 AM
blahblahfoo
Default Heli Coils for Valve Cover bolts on a 1994 Honda Accord with VTEC engine
So i have a 1994 Honda Accord with a VTEC engine. There are 5 bolts holding the valve cover on on the engine. The Engine block threads are stripped/missing thanks to the previous owner screwing in the bolts too tight. What size heli-coil kit should i get to fix the engine block threads? Also, should i still use the original bolts, or get some new ones? Remember its the engine block threads not the bolts
Old Oct 6, 2008 | 05:44 AM
Default RE: Heli Coils for Valve Cover bolts on a 1994 Honda Accord with VTEC engine
The Accord valve cover sealdoesn't require a lot of pressure and it may work fine w/o repairing. I have one that one tighten up, but exerts a little pressure. The spark plug tube seals dont really require a lot of pressure since they have a sliding seal primarily.
Ifrepaired, I would be tempted to have done professionally to avoid making problem worse w/ improper repair.
Old Oct 6, 2008 | 11:16 AM
You choose HeliCoil size as the original thread size. It needs to match up with the VC bolts. The kit has a special strange size tap which you use to chase the holes.
They arent too hard to install, just follow directions & be careful about tapping the hole straight & true. Theres 2things Id worry about...
1 -you have to enlarge the holes - is there enough metal surrounding the holes?
2- keeping themetal chips out of the engine.
Of course, dont overtighten the bolts...
Old Feb 19, 2012 | 12:00 AM
Razorofpow's Avatar
I had the same problem... lol pissed me off it was the front drvr threads that it happened to
hman
Nov 23, 2015 11:22 PM
cd51994accord
Jan 30, 2014 12:56 PM
03Sleeper
Jun 11, 2008 08:54 PM
live2rice
Feb 5, 2008 06:22 PM
Planefreak
Jan 5, 2008 06:03 PM
