Hello I'v got a 04 accord 2dr coupe window motor problem
Old Feb 13, 2011 | 09:14 AM
mcgiver488's Avatar
Default Hello I'v got a 04 accord 2dr coupe window motor problem
Bought car used after a few months the driver side motor quit took it apart found the cheapest constructed electric motor I'v ever seen held together with sheet metal screws and no brush holders just a peices of spring steel bent in a L copper coated with a peice of brush material glued to the end what had happened was from the current going through the spring it heated up distorted like all springs do when heated and no more brush to armature contact . I would rebend the spring and the motor would work for 3-6 weeks then the same thing even tried replacing the whole rack ,motor assembly with a new one from fleabay window goes up and down quickly and smoothly when the motor works the new assembly lasted 3 months same problem . I'm wondering if it's something to do with the master switch that you have to teach wher the top and bottom of the window travel goes. Can't find any recalls on it HELP.
jon b
jkeely
May 2, 2012 03:48 PM
ravenr106
Oct 21, 2011 06:08 AM
ravenr106
Oct 20, 2011 05:32 PM
cengland84
Oct 28, 2008 01:20 PM
bigspilv
Jan 8, 2007 06:01 PM
