Help! @ a Job Site...
Old Nov 27, 2007 | 09:07 AM
falkore24's Avatar
Default RE: Help! @ a Job Site...
x3 .... on printing out DH's thread. As noted earlier ..... try jumping the car. This may be as simple as a bad battery from the factory. Stranger things have happened!
Old Dec 17, 2007 | 09:08 AM
RoKnAzn's Avatar
Well, I got my Truck and Trailer to hawl the Accord home. When I got home from the5 hourroundtrip. I tested the battery and it was good. Then I tested the Starter and it was good. So, I have might havea bad ignition switch, a fuse, starter relay, wiring, clutch switch, or whatever. At this moment I have a hot wire with a switchrunning to the Starter. So I can start teh car for Temp. What should I do?
What I have Checked...
The Starter Fuse under the Dash
Starter
Battery
So far I have replaced on this Honda...
Main Relay
Battery
Time Belt
Acc. Belt
All Water Cooling Hoses
Rear Wheel Bearing
Rear Sub Frame
Fuel Filter
Air Filter
Old Dec 17, 2007 | 01:59 PM
If your starter is working properly, then I would pull the plug on the clutch interlock switch and jumper that plug with a paperclip. This will fool the car into thinking that you have the clutch pushed in. Make sure your are in neutral when trying to start the car.
If the car starts with no problem, then replace the clutch interlock switch.
Old Dec 17, 2007 | 07:30 PM
HondatechAV6's Avatar
ORIGINAL: PAhonda
agreed. if it starts now with the clutch safety switch jumped either replace it or clip the wires and twist them together(permanent fix). just make sure you don't start it in first! hahaha....anyway, if it's not the switch let us know.
Old Dec 18, 2007 | 08:07 AM
RoKnAzn's Avatar
ORIGINAL: PAhonda
YEA! It's the Clutch Switch..hehe So, I order another Switch from Advance Auto Parts and it comes with a year warrenty. BTW, What is the Other Switch that is alittle bigger then the Clutch Switch?
Thanks
Anthony
Old Dec 18, 2007 | 04:56 PM
nafango2's Avatar
...the other switch thats a little bigger than the clutch switch?
could it be the brake switch?
im not really sure if they have this on hondas or not, mines an auto, but a lot of cars they have one switch on the top of the clutch to tell when its full engaged and one on the bottom that can tell if its fully depressed. is the top one what you were talking about?
Old Dec 18, 2007 | 06:52 PM
  #17
if it's on the clutch pedal probably the cruise control switch.
Old Dec 19, 2007 | 11:40 AM
  #18
RoKnAzn's Avatar
ORIGINAL: HondatechAV6
Ahh...that sounds right..
98jeepzj
Feb 11, 2009 06:57 AM
mestnf
Jan 17, 2008 07:22 AM
mig25
May 19, 2007 11:35 AM
Cody Is Cool
Apr 7, 2007 08:29 PM
louisville_slugger89
Mar 3, 2007 07:28 PM
