Help on 2012 LX iVETC solenoid gasket part#
Old Jul 18, 2020 | 11:33 AM
johnx's Avatar
Default Help on 2012 LX iVETC solenoid gasket part#
Planning to replace 2012 Accord LX valve cover gasket due to some oil leak, and would like to replace the iVETC solenoid gasket as well. Spent quite amount of time on internet, just couldn't find the right solenoid gasket. Could someone tell me either OEM or aftermarket part#? Thanks!
Old Jul 18, 2020 | 01:06 PM
I'm not as familiar with the differences between trims on the 2012 accords. I'm also not sure what gasket you are trying to replace. I think you are trying to replace OEM part number 15815-R40-A01, but I am not sure.
The easiest way to find the OEM part number is to go to hondapartsnow.com and use your VIN to get the correct model/trim of your accord. The gasket diagram an OEM part numbers are listed under the engine then vtc control solenoid valve.
Old Jul 18, 2020 | 03:36 PM
johnx's Avatar
wow, that makes life much easy! really appreciate it!
Old Jul 19, 2020 | 10:33 AM
hondaslave1342's Avatar
That's exactly what I do..
pepaccordcd5
Dec 5, 2019 08:51 AM
Moochdog
Jan 21, 2017 06:22 AM
djkurious
Apr 13, 2014 10:35 AM
luis landa
Dec 26, 2010 04:22 PM
elvis1977
Oct 11, 2010 05:06 PM
