Help!!
Old Aug 21, 2025 | 04:43 PM
Nope, the belt will still be pretty snug. Just peel the belt from the cam sprocket up top. Try to hold some tension on the belt to keep it on the crank sprocket below. Rotate the cam sprocket in the direction to get it to TDC, the pull the belt over the cam sprocket. Tension the belt like in the video, then spin the engine by hand a few revolutions, then recheck the timing marks. Repeat until you are sure the timing is properly set.
Old Aug 21, 2025 | 04:46 PM
BrandonP002's Avatar
Ok I just pull the whole rocker assembly off because I wanna remove the head since I ordered a whole gasket kit and there was a lot of black chunky/crispy stuff all over the exhaust valve springs which is a little concerning and imma redo the valve seals and possibly surface the head
DeadStreet
Jan 23, 2024 11:52 PM
plumerted
May 15, 2023 04:58 PM
jazzyjasper
Apr 10, 2022 12:32 PM
Calvin
Mar 28, 2022 09:36 PM
75Gremlin
Jan 12, 2022 05:51 PM
