HELP with Check Engine Light
Old Nov 9, 2012 | 10:31 AM
beateraccorddriver's Avatar
Drivers side underdash, #6 fuse....pretty sure you are not the SULEV but they have another in the pass side underdash #6 as well.
Step one of testing the p0135.
Thanks, fuse 6 looks to be good
Old Nov 9, 2012 | 06:30 PM
So, what did step on of the testing show?
Old Nov 11, 2012 | 02:24 PM
step one was good, im waiting for a header to come in the mail to see if it was my manifold causing the problem
Old Nov 12, 2012 | 06:13 PM
Well, while waiting for that....willing for part two.....and we are one page two and I can't remember what year/engine we are working on....this is got the 6th gen 4cyl.
Attached Thumbnails HELP with Check Engine Light-6th-gen-p0135-test-4cyl-part2.jpg
Old Nov 17, 2012 | 12:57 PM
sorry for the delay - the header came in and i installed that along with a new upstream o2 sensor.. erased the p0135 with scanner and instantly come back on again.. also while installing the header i noticed the engine code on the block f23a7 so it seems it is not ulev but has a ulev valve cover.. i checked the resistance of the sensor and it went to 19ohms and the others test showed 12 volts dc which all seems to be to spec? any further help would be appreciated!
Old Nov 17, 2012 | 01:24 PM
Old Nov 18, 2012 | 02:44 PM
  #17
i did this and everything came back normal
Old Nov 18, 2012 | 02:51 PM
  #18
The link states:
"If the Diagnostic Trouble Code does come back... there are several possible scenarios:
  • Intermittent short in the O2 Sensor's wiring (that only presents itself when the vehicle is in motion).
  • A BAD O2 Sensor (even tho' it tested OK in this test section).
  • A BAD Fuel Injection Computer (this is rare, but it does happen).
Although it's beyond the scope of this tutorial to test for tha above conditions... my suggestion to you, before replacing the Fuel Injection Computer, is to try another O2 Sensor first and go from there."
Old Nov 18, 2012 | 05:56 PM
  #19
thank you for the input i will keep trying to solve this problem
Old Nov 19, 2012 | 02:45 AM
  #20
if i took this to a shop to have them try to get rid of the cel what would you guys thinks it would cost.. should i go to honda or somewhere else?
Mott
Mar 15, 2016 11:25 AM
ddold@gkschools.org
Jan 29, 2008 03:35 PM
hotrod01
Nov 11, 2005 01:28 AM
