Help with Code fixes....
Old Jan 30, 2012 | 07:30 PM
TuMMo's Avatar
Default Help with Code fixes....
1996 Accord 2.2 non-vtech...
I checked the codes by using the paper clip trick and came up with the following... Pardon the ignoance, Im new to this...
Code 9---Cylinder Sensor
Code 17---VSS Vehicle Speed sensor
Code 65---Secondary O2 Sensor Heater
Can anyone tell me the fixes on these problems?
Thanks guys,,,
Old Jan 30, 2012 | 08:58 PM
Well the 96 sould also read the OBDII code but we can try with these.
Not sure what issue (main) that you have.....I'm gussing the code 9 (no start)?
Do you have a volt meter and can you check the resistance of the sensor?
Old Jan 31, 2012 | 06:06 AM
TuMMo's Avatar
Car runs fine, Starts fine just has a little rpm bounce when I coast. Just changed head gasket, timing belt, balancer belt, all that could be changed. The CEL has been on for a while just was seeing what issues I had and how to resolve them. No voltmeter! I'm going to change the vss and the o2 sensor ( if I can figure which one) but was wondering about the crankshaft sensor.
Old Jan 31, 2012 | 09:28 PM
Ok, at least for the O2, if you are going to replace without testing....replace the "downstream" one
Have you ever reset them to see if/which ones come back?
HatchJunki
Mar 9, 2013 08:23 AM
accordhybridowner
Jan 27, 2012 04:31 PM
Tuttlebot
Dec 30, 2011 08:49 PM
noob447
Apr 29, 2011 03:54 PM
rtmobile96
Apr 10, 2008 12:43 PM
