help coolant problem
Old Oct 17, 2012 | 04:15 AM
beastyme's Avatar
Default help coolant problem
Hey new to this forum and hondas jus bought my first 1 its a 95 accord v4 vtec my problem is that while driving I can smell the coolant leaking bt its nt leaking its jus steaming out of the radiator cap and overflow bottle I hav replaced the cap bt still steam leaks out while driving its a new radiator although it might b from a 98 n nt a 95 also my temp gauge is fine car never overheats according to the gauge bt releases steam from cap and overflow bottle n I have to top off radiator ever few days please sum1 help any input is welcome
Old Oct 17, 2012 | 05:52 AM
shipo's Avatar
I'm guessing heater hose, radiator hose, water pump or even the heater core (is the carpet in the passenger foot well damp).
Old Oct 17, 2012 | 07:08 AM
Welcome!
I'll move this over to General Tech where it belongs.
Old Oct 17, 2012 | 12:32 PM
beastyme's Avatar
The hoses are fine n the water is pumping the the system five by the looks of it the carpet is nt wet . What is the heater core
Old Oct 17, 2012 | 01:05 PM
shipo's Avatar
The heater core is like a mini radiator in the dashboard that has cabin air run through it for cabin heat. There are hoses in the engine compartment that typically link the engine near the water pump to the firewall nipples for the heater core.
Old Oct 19, 2012 | 05:01 AM
holmesnmanny's Avatar
Are you overfilling the overflow bottle ? It should only be filled up about halfway in the bottle itself. It shows the "MAX FILL" mark. It's only about halfway up the bottle. If you overfill it, when the car heats up the system is going to expand and it will overflow. If you aren't overflowing and the car isn't overheating you could have a blown headgasket. You should do a compression test.
ghostgxz
Jan 18, 2013 01:50 AM
AkbarGr8
Sep 8, 2010 06:28 PM
mamtsberg
Mar 17, 2010 09:15 PM
bgtcket5
Aug 9, 2007 05:48 PM
lm_dicp
Feb 19, 2007 11:03 AM
