Help door wont open :(
Old Apr 23, 2013 | 05:42 PM
InTrouble's Avatar
Default Help door wont open :(
Hello, I have a 2006 (or is it 2007 not 100% sure) Honda Accord 2door that won't open up. I have my keys and the buttons respond, but the door won't open. I cannot open the door with my keys because the left side door has been replaced, and the keys I have work with the ignition, but not the door. I know I should call some sort of service to have it opened, but I am really broke right now and cannot afford it. The trunk does not have a key hole, nor does the passenger side door. Is there any way that I can open the door myself?
Please help guys!
Old Apr 23, 2013 | 06:11 PM
Can't you use keys to open RH door, then reach across and open LH door from inside by lifting manual lock release?
Old Apr 23, 2013 | 06:17 PM
Hello New Member, did you give Tex's answer a try out yet.?
Old Apr 23, 2013 | 07:10 PM
InTrouble's Avatar
@TexasHonda, no unfortunately my right hand door does not have a keyhole on it. Only the left one does, and as I mentioned the keys I have only work on the ignition and not on the door. Are there any tools that I can purchase to open the door? My friend recommended this from O'Riellys, but I have no idea how to use it. It's around 6 dollars.
Performance Tool W1147C - Car Door Lockout Tool | O'Reilly Auto Parts
Are there any guides out there? And would this be the only tool I would need to purchase? I'm sorry I am terrible with cars, and just really can't afford to spend a lot just to get my door opened.
Old Apr 23, 2013 | 07:37 PM
Sorry, I didn't realize coupes only had a LH key lock.
I know it may be painful, but in the long run it may be cheaper to get help, particularly if you need your car to get to work.
Suggest checking w/ local locksmiths for best price.
I would be very surprised if that tool will work, but don't know for sure.
Old Apr 23, 2013 | 07:41 PM
what do you mean that the buttons respond?
If you hold the lower right button, that should allow the trunk to open up.
Old Apr 23, 2013 | 09:12 PM
InTrouble's Avatar
My car keys only have a lock/unlock and Panic button on them. No unlock trunk button. And when I mean they respond, if I double tap the lock button, the car will give off a sound to confirm it locks. If I press the panic button, the alarm goes off. If I tap unlock, all that happens is the red button blinks, but door doesn't unlock.
Sigh I just gave in and got it opened by a locksmith, 50 dollars bye bye
Thanks anyways for the help guys. I appreciate.
Old Apr 23, 2013 | 09:56 PM
Sorry about that. You will need to figure out why the remote was not working properly.
I think a locksmith should be able to change the door lock to match your key. If not, you may want to get a key made for the driver's door lock. I am not sure how you would find out the VIN of the donor car.
Old Apr 24, 2013 | 08:29 AM
Dr. Drivability's Avatar
press the unlock button once and then again within 2 seconds and HOLD it down, the windows should roll down. if not, you'll need to bust out a window or call a locksmith.
Old Apr 25, 2013 | 05:02 AM
InTrouble's Avatar
Thanks for the cool trick bro, but the windows only seem to open when the car is unlocked.
bruce777
Jun 4, 2015 11:21 AM
MrGmo
Sep 28, 2007 01:40 AM
maro
Mar 26, 2007 07:08 PM
smoothoperator
Jan 30, 2007 09:00 PM
