Help idle problem or something else?
Old Jan 7, 2015 | 11:59 AM
Allie_El's Avatar
Default Help idle problem or something else?
I have a 1996 Honda accord LX I am having trouble with I'm assuming the idle. I've changed the tps and the iac and it still revs up and down on its own and does a "weeooo" noise. When I drive it goes as far as I between 3 and 4 rpms and then goes back down. When I put it in park the "heartbeat" starts, when I but it in gear it goes away. I can't figure out what is wrong with it or what else it could be.. Does anyone have any ideas? Is it a vacuum leak?
Old Jan 7, 2015 | 01:02 PM
Turtlehead's Avatar
Certainly be checking the vacuum lines regarding this. I have to assume that it is an AT given your post, but please post back with transmission type.
Old Apr 4, 2015 | 01:28 AM
DiggerDave's Avatar
Check the fast idle control valve.. clean the plunger and tighten down the outer ring. Google it.
darkgreen18290
Oct 25, 2011 05:18 AM
abhijitgp
Apr 3, 2011 10:30 AM
mizuvortex
Feb 17, 2011 11:55 AM
dupydog
Feb 12, 2008 03:14 AM
ckebottle
Dec 13, 2007 09:04 PM
