HELP!!!! im having electrical problems
Old Sep 21, 2010 | 01:42 AM
brettboone1990's Avatar
Exclamation HELP!!!! im having electrical problems
ok so im new to the honda scene, i have a 97 honda accord es and its not starting, im not getting a spark to the distributer from the coil pack and i just replaced the coil pack and spark plugs. i have no idea what it could be, any suggestions?
Old Sep 21, 2010 | 06:29 AM
I think there's a thread in the DIY section about how to tell a problem in the ignitor vs. coil. Check that out.
Old Sep 21, 2010 | 11:59 AM
Also check whether you are getting 12V to the distributor on the Blk/Yel wire w/ keyswitch ON. If no voltage, then keyswitch assy is the problem.
Old Sep 21, 2010 | 01:30 PM
Jim Blake- I couldnt find the thread.
Texas Honda- its not sparking from the coil pack to the distributor, its trying to turn the motor over but no spark
Old Sep 21, 2010 | 01:51 PM
deserthonda's Avatar
Old Sep 21, 2010 | 03:30 PM
The ignition switch has to maintain THREE different circuits.
Accessories
On when the switch is in "ACC" & "ON" positions
Ignition
On when the switch is in "ON" & "START" positions
Starter
On when the switch is in "START" position
The reason I spell this out is one way for the switch to fail is the ignition doesn't get power while the starter DOES. It's like 3 separate switches rolled into one. So just because the starter cranks, that doesn't prove that the switch is providing power to the ignition circuit. It only proves the switch is providing power to the starter-signal circuit.
Atl golfer
Feb 14, 2013 08:41 PM
04SatinAccordTX
Jun 17, 2008 12:21 PM
