help me identify this leaking part
Old Aug 6, 2010 | 07:52 PM
renegade05's Avatar
Default help me identify this leaking part
This part leaks sometimes. I have no idea what it is or what its leaking. I bought the Haynes service manual but cant seem to locate what the part is. It does have a picture of it though. I have included some pictures of what im trying to identify.
PLEASE HELP!
Thanks in advance.
by the way only the front right one is leaking.
Attached Thumbnails help me identify this leaking part-img_0294.jpg   help me identify this leaking part-img_0295.jpg
Old Aug 6, 2010 | 08:37 PM
What year, model (ex-l, ex, etc...), engine (4/6 cyl), transmission (at/mt) do you have?
Old Aug 6, 2010 | 09:35 PM
renegade05's Avatar
2001 Honda accord ex 4 cylinder manual tranny.
Old Aug 6, 2010 | 10:03 PM
kris_loehr's Avatar
You circled part looks to be a busing in the sub frame and it looks like you have a photo of both the front and back. Not an item that can leak. The closes leaking item in your photo I see to your circled part is the steering rack which is number seven in the photo of the front suspension.
Old Aug 6, 2010 | 11:25 PM
bigdawg74's Avatar
What color is the fluid that is allegedly leaking?
Old Aug 7, 2010 | 12:35 AM
clutch811's Avatar
the pictures you gave are that of a v6 accord. not sure if their suspension is very different or not. the front appears to be a leak from the steering rack, however it can still be oil leaking and running down to those points. do you loose oil? best bet is clean that engine bay and sub frame really good and then keep an eye out for where its really coming from.
Old Aug 7, 2010 | 02:15 AM
renegade05's Avatar
thanks for the responses guys. Ya, its just the front right one that is leaking. almost seems like its just water, but it hasnt rained in a couple weeks. Very strange. no oil is being lost or anything that i know of. My master cylinder requires probably more than the average top up. could it be hydraulic fluid from either the braking mechanism or tranny?
Old Aug 7, 2010 | 08:05 AM
Right front, looks like water? Is the rad full. Does the "fluid" smell or feel slick. Also be sure it isn't just the AC drain that you are seeing, pretty sure that on an '01 it is in that area as well.
Old Aug 7, 2010 | 11:45 AM
renegade05's Avatar
could be the AC i suppose. It has been hot here for a while so i have been using it everyday.
Old Aug 8, 2010 | 12:01 AM
EXV6NIGHTHAWK's Avatar
Wipe the fluid with a white cloth, so you can tell what color it is. Probably just water dripping from the air conditioner (normal). Do you see the end of a hose above/in front of that area (A/C drain hose)?
iyhan
Dec 4, 2012 08:00 PM
kdillon13
Oct 18, 2012 02:36 PM
VelvitJones
Mar 23, 2012 07:01 PM
atsioukl
Jul 8, 2010 01:37 PM
klrspz
Mar 13, 2008 09:03 AM
