help with my 2004 6cyl!!!
Old Mar 30, 2009 | 06:16 PM
embpilot's Avatar
Default help with my 2004 6cyl!!!
hey guys,
I have a 2004 accord 3.0l. It's been idling rough and lacking accleration and wants to cut out on occasion. when I hit the gas it is really sluggish. EGR ports/valve?...If so Whats the best way to clean it? any ideas at all?? Thanks in advance
Old Mar 30, 2009 | 07:24 PM
hondadude's Avatar
Well, the EGR system doesn't come into play at idle or under load.
Does the ECU have any codes stored? CEL light?
A common problem is to have crud build up around the throttle plate and/or the IACV screen gets plugged up.
Berrymans B-12 is my favorite flavor of throttle body cleaner, you can scrub around the throttle plate with Berrymans and a toothbrush.
Just take the IACV loose from the throttle body and blast out the screen with Berrymans and compressed air.
Old Mar 30, 2009 | 08:36 PM
embpilot's Avatar
Default thanks
thanks..ill try that....any other ideas are much appreciated
EPH6PWR
Jul 25, 2009 01:51 AM
XYKD
Dec 17, 2008 11:30 AM
taengok
Aug 30, 2008 11:18 PM
Chaqui04
30
Jan 25, 2008 05:34 PM
jp28
Mar 31, 2006 10:05 PM
