Help! Stripped wheel cylinder bolt.
Old May 25, 2017 | 10:23 PM
hondafromhell's Avatar
Default Help! Stripped wheel cylinder bolt.
Hey guys, I recently replaced the rear brake drums/shoes/wheel cylinders on my 1997 Honda Accord SE. After bleeding and driving I felt like there may still have been air in the lines. I went to bleed again and noticed one of the new wheel cylinder boots seemed. Having just bought it I decided I would go get it replaced only to find that one of the two bolts (10 mm) holding it in is stripped and wont budge. I have tried penetrating oil but only just one time. I can't seem to be able to fit a socket on there because there is no clearance on the side the stripped bolt is on. Of course, it started getting dark and I had to call it quits for the night. I don't want to cut the bolt because I would like to replace the cylinder for a new one (and yes i know how cheap they are, but I still would like to exchange it) I don't have any torch available to me at the moment and was just wondering if anyone had any ideas on how to get this bolt off. Thanks!
Old May 25, 2017 | 11:18 PM
Not sure why you can't cut the head off, remove the cylinder, then use some vice grips to remove the remainder of the bolt.
Can you get a chisel in there at an angle to knock the bolt loose?
Old May 26, 2017 | 01:02 PM
I dont have access to a saw at the moment. I am going to try the chisel method hopefully that works if not i will be hacking away.
Old May 29, 2017 | 12:38 AM
Got it out with a hammer and a chisel...
theDex
Oct 14, 2012 10:49 AM
Jet sitter
Apr 7, 2012 07:29 PM
jambai
Mar 2, 2008 07:34 PM
Play4802
Jun 23, 2007 08:43 PM
suprarx7nut
Jun 21, 2007 12:03 AM
