Hesistation on acceleration, bogging
Old Jun 28, 2006 | 03:19 PM
sir_nasty's Avatar
Default RE: Hesistation on acceleration, bogging
your oil being low will actually affect your performance, expecially on a v-tech. It uses oil pressure to engage the second cam so that would explain why low oil would give you performance issues... let us know if that fixed it.
Old Jun 28, 2006 | 07:25 PM
nixalot's Avatar
Mike,
Another thought just hit me... what type of plugs did you put in the car when you changed them out?
Old Jun 30, 2006 | 01:32 PM
Mike7311's Avatar
The car feels much better now that the oil level is up, not great just better. I have NGK spark plugs, OEM. Since I cleaned my EGR I have experenced twice my car stalling under extremely heavy braking, mostly when I'm testing it for differences. It feels like the Torque converter isn't letting go. I may need to adjust my idle?
Old Jun 30, 2006 | 03:20 PM
nixalot's Avatar
ORIGINAL: Mike7311
My '96 does something similar under heavy braking... it's like a delayed shift back down from 2nd to 1st, and when it does shift it lets go at the last minute... but mine doesn't stall. This has my curiosity aroused now... keep us posted on anything that you find out...
Old Jun 30, 2006 | 05:32 PM
Mike7311's Avatar
I just figured out the hesistation issue. It seems that good o'V2 intake is bogging my engine at take off (Too much air). Though, it does add power on the high end, I'm seriously considering switching back to a stock set up with K&N filter. Unless anyone has a suggestion on restricting flow at takeoff and opening up at the high end.
The stalling issue likely has to do with my EGR cleaning, which I believe broke carbon lose and is now stuck somewhere farther down the line of the port, IAC maybe?
Afnan
Jan 11, 2014 02:55 PM
97accord
Apr 29, 2012 06:58 PM
Diagram14
Oct 9, 2008 08:28 AM
josephaj08
Aug 13, 2007 11:27 PM
new_oldHondaOwner
Apr 24, 2006 07:52 PM
