hesitation on reversing in accord 98
Old Nov 14, 2015 | 03:35 PM
Rilex's Avatar
Default hesitation on reversing in accord 98
hello to you all my honda accord occasionally takes time to pick up when pressing the pedal and then suddenly speed up, similar things happen on reversing. The transmission shifts very well. I am thinking one of the sensors is going bad, although no scan results yet. I want to find out if i can quickly make a journey of 68km on monday and come back on wednesday without any breakdown. When i come back from the trip i will do the repairing. Honda Accord 1998, mileage 220,00. Auto transmission 4cylinders, Lx. Hoping to hear from you all soon. Thanks
Old Nov 15, 2015 | 09:29 AM
A change of ATF using Honda DW1 ATF may improve shift response.
As AT's age, they sometimes exhibit slow shifts (P>N>D & D1>D4) and require a pause (reduced throttle) to allow shift to occur, whether moving or stopped. You can drive a car for years w/ slow shift problem. It helps to let up on gas as shift point approaches.
For slow shifts when changing from P-N to D4, only solution is to wait for shift to occur before applying throttle.
Old Nov 15, 2015 | 09:35 AM
Turtlehead's Avatar
Sticky throttle plate/external linkage or failing throttle cable can cause those symptoms.
chieflief
Nov 4, 2010 07:27 PM
Geemoh
Jan 11, 2010 07:31 AM
jerico
Oct 17, 2007 10:26 PM
daddave
Feb 7, 2007 03:01 AM
joe592
Sep 9, 2006 04:34 PM
