HID problem
Old Nov 21, 2008 | 02:31 PM
cjdm98's Avatar
Default HID problem
So im driving home last night and boom,my left hid light goes out.. so i called the person who i baught it from because of warranty or what not,so i had both bulbs replaced and i go to turn them on and they both dont work,so the guy switches ballast and same thing,still dont turn on,so i went on a mission to my job to buy two new headlight relays and a bunch of 20Amp fuses,changed everything and still doesnt fire up.. so just now i put my old halogens in there,and they came on just fine.. am i missing something here.. input please.
Old Nov 21, 2008 | 02:38 PM
finch13's Avatar
Default RE: HID problem
How are you HIDs wired?
Are they Headlight Plug -> Ballast -> Bulb
Or Battery -> Relay -> Ballast -> Bulb?
20A fuses are more than plenty, I have 5A inline fuses for mine and my ballasts are rated for like 7A or something and they don't burn out... you may be frying the ballasts somehow.
Old Nov 21, 2008 | 03:15 PM
cjdm98's Avatar
Its headlight>balast>bulb..
But the thing is now i notice that when i flick the light to come on it clicks,and i cam here it coming from the fuse box under the hood.
Old Nov 21, 2008 | 03:18 PM
finch13's Avatar
You relay contacts are probably worn out... that's what's clicking the fuse box.
Old Nov 21, 2008 | 03:22 PM
cjdm98's Avatar
I read that the HID and or ballast arent getting the right amout of power to operate properly..and i need to install a relay harness kit?
Old Nov 21, 2008 | 03:28 PM
finch13's Avatar
Possibly... you can make you're own, I did. Basically, with the kit, the ballasts draw their power directly from the battery and not through the switch on the steering column.
Old Nov 21, 2008 | 03:30 PM
cjdm98's Avatar
Yeah im on my way to my boys shop to pick up the kit right now...I'll be back in a bit dude. Thanks
Old Nov 21, 2008 | 04:09 PM
finch13's Avatar
Nice, let us know if it fixes it!
Old Nov 21, 2008 | 06:03 PM
cjdm98's Avatar
All is good in the under the hood.
Relay was just what i needed...This almost ruined my day.
An D. Nguyen
Aug 13, 2013 09:59 PM
chintan007
May 22, 2011 06:20 PM
GreekBoy
Nov 14, 2008 11:40 PM
AyashiFX55
Jun 5, 2008 07:55 PM
Nolimit167
Feb 19, 2008 08:37 PM
