High water trouble
Old May 18, 2014 | 01:42 PM
troydsmith's Avatar
Default High water trouble
My 1999 Honda Accord started having tranny problems after hitting a large puddle of water during a thunderstorm last week. shortly after hitting the water my D4 light began to flash and the car stopped shifting past 2nd gear. I thought it just needed to dry out but after 2 days the problem still exists. I took it to the shop and had the codes read (P0700, P1705). the mechanic cleared the codes and for a few minutes the car ran fine (shifting normally) but the codes came back and the problems started anew. my thoughts are leaning toward shift solenoid B. any thoughts will be appreciated.
Old May 18, 2014 | 01:59 PM
EXV6NIGHTHAWK's Avatar
Have you checked the fluid level, and for water contamination? If those codes are for the solenoid, you might want to clean the electrical connectors with some electric cleaner and maybe even take the solenoid off and clean it too if nothing else works. Good luck
Old May 18, 2014 | 02:35 PM
troydsmith's Avatar
checked all fluid levels and they were good. gonna keep working down the list an hopefully some info will come through that will lead me in the right direction.
PepeLePew
Jun 2, 2012 10:49 AM
MICHOASTYLE
Mar 15, 2012 06:16 PM
yamahabalu
Sep 28, 2009 02:11 AM
95EXV6
Jun 27, 2005 08:21 PM
Getsch
May 24, 2005 07:52 PM
