Hill break
Old May 28, 2011 | 01:15 PM
troycifer's Avatar
Default Hill break
I have a 01 accord coupe. My hill break(e break) is barely breaking even if pulled all the way up. Can I tighten it or is the cable stretched and needs replacing?
Old May 28, 2011 | 02:08 PM
I'd inspect the pads/shoes and make sure. Is the a disc or drum set up on the rear? Yes the cable can be adjusted but that should be rare.....I can't ever remember adjusting the cable on any of my Honda's. Just my opinion and experience.
Old May 29, 2011 | 07:51 PM
ReallyaDodgeGuy's Avatar
Yes, the cable can be adjusted but it shouldn't have to be.
Most, if not all, newer cars have brakes that auto-adjust as the pads/shoes wear out. I've found that once the e-brake gets sloppy like that it's normally time for brakes. Also, if one or both of your rear calipers are sticking I've seen that create a dead e-brake.
My 94 Accord had zero e-brake when I bought it. Turned out that the slide pins for the rear calipers had frozen from rust over the years. Sometimes it's the simple things that'll bite ya in the ***.
Old May 29, 2011 | 08:42 PM
troycifer's Avatar
Pads are fine but one of the back brakes is seized. when that's fixed I'll check it again
moey
Jun 23, 2021 09:45 PM
jaycey001
Jan 29, 2014 09:39 AM
Onlooker
Sep 4, 2009 09:18 AM
Moppie
May 15, 2009 05:19 PM
bigheadballer
Aug 27, 2005 08:16 PM
