hit a tree 04 sadan
Old Feb 4, 2009 | 07:22 PM
clutch it up
Default hit a tree 04 sadan
so last night ******** dident plow ar salt the roads and i hit a tree. air bag came out was wondering if i had to replace any impact censer i would also like to know where to get cheaper parts i need a hood, driver side airbag, front bumper cover and impact bar. how do you reset the seat belt from the locked position. how do you reset the airbag dash light. thank you for any help
Old Feb 4, 2009 | 07:37 PM
finch13's Avatar
Let's go through this together:
So it's somebody else fault you didn't take caution by slowing down when you come to an unplowed road? Not their fault.
Your car will be marked as totalled by the insurance company. Air bags and their components are expensive, probably a good $1000 or more if you DIY (which I do not recommend)
Junkyard is always the cheapest and easiest. Try car-part.com to search your local yards. You also probably need a lot more in parts than just what you listed. Radiator support, etc. If the airbags went off, there is definitely more damage.
Pull on it and slowly let it retract.
Depends. You can try just disconnecting the battery, but since the airbags went off, the unit may need to be replaced to get the light off.
dowell47
Jan 16, 2012 10:16 PM
pbplayer257
Apr 1, 2010 01:17 PM
RaizinnBran
Jun 24, 2009 08:58 PM
