Hitachi vs. TEC distributors.. are they swappable?
Old Apr 16, 2016 | 06:30 PM
Joe Ang's Avatar
Default Need 96 Accord HELP!
Originally Posted by thericepatch
I have actually done this swap on a 96 accord, mostly for the availability of parts. It is just a bit of splicing in the correct wires. I cut the hitachi connector off the car harness since I don't intend to use it again, and spliced in a tec connector. The black/yellow wires go together, the blue on the connector with the black/yellow connects to the blue wire on the car harness. From the large connector the yellow/green goes to the same, and the shielded pair mates with the other two. black to the orange, white to the yellow/ shielded purple. The other wires are not used because the sensors are duplicates of the crank sensors.
Have a 4-2.2L F/inj. (16V) SOHC F22B1 V-Tec 1996 Accord EX with the Hitachi Distributor. Need to replace the coil. Have the new coil. As dumb as I feel asking this; how does the old one "slide" out? First time for me not doing the spring type. If you have a pic. or can help it would be so much appreciated. Thank you, Joe
Old Apr 16, 2016 | 06:32 PM
Joe Ang's Avatar
The "non-spring" type. Sorry first post had a typo.
Old Apr 16, 2016 | 10:47 PM
The Toecutter's Avatar
Remove the cap, then the 2 screws on the coil end, and it should come out. You might need a wrench to hold the nuts (if equipped) to get the screws out.
Note, I'm working with a TEC distributor on my 97 16 valve engine (non V-tec), but I think the housings are the same (just what's inside are different from what I can tell from the FSM).
Old Apr 17, 2016 | 05:55 AM
Joe Ang's Avatar
Default Hitachi
Appreciate you taking the time, but sadly the Hitachi distrib. uses a diff. coil.
Old Apr 17, 2016 | 06:58 AM
For the internal coil, there are two screws holding the coil, then two (?) screws holding wires to the coil.
Old Apr 17, 2016 | 08:41 AM
That was the point I was trying to make to Joe. The coil is held inside the distributor by 2 screws to the distributor body.
Yes Joe, I do know the Hitachi and TEC coils are different, both in location and in mounting.
Old Apr 17, 2016 | 09:32 AM
  #17
Joe Ang's Avatar
OK. I will look for screws again? Wires slide onto "sled type" posts on my existing original coil. Appreciate your time. The "spring" type coil was a piece of cake to change compared to this. :0(
Old Apr 17, 2016 | 10:25 AM
  #18
Are you replacing the coil or the ICM?
Pic's.....pic's....pic's
Old Apr 17, 2016 | 12:24 PM
  #19
Joe Ang's Avatar
Am installing (trying to anyway) this coil; New Ruf 123 Ignition Coil Honda 1994 2002 Acura 1997 1999 Isuzu 1996 1999 UF123 | eBay
Although not a mechanic this is the first time in a long while I have had such a problem.
Getting old I guess?
hallstevenson
May 7, 2015 01:59 PM
martinez289
Mar 1, 2013 06:33 AM
rederik13
Dec 23, 2012 09:33 AM
jdittmann
Jun 29, 2011 11:51 AM
jjyynnxx
Jul 26, 2006 03:41 AM
