Homelink problem
Old Feb 5, 2009 | 02:35 PM
alvinh
Default Homelink problem
I have a 2008 Accord. My Homelink to my garage door opener works all the time. The one to my village gate only works for a short time after its programmed. Anyone ??
Old Feb 5, 2009 | 08:39 PM
Arrow
I will move this to a correct thread for you..Please observe the posting rules ...Thank You!
Old Feb 9, 2009 | 12:41 PM
alvinh
Thanks
Old Feb 9, 2009 | 12:45 PM
finch13's Avatar
The gate probably uses a code hopping transmitter/receiver. Your Homelink is probably picking up the current code, working for a bit, and then stops working when the code changes to the next one.
Old Feb 10, 2009 | 12:48 PM
alvinh
I've not had this problem with other cars homelink systems, which were programmed the same way that I programmed the on in my accord.
Old Feb 10, 2009 | 12:54 PM
finch13's Avatar
Well, the car should be under warranty, you could take it in to Honda and talk to them. You could also try talking to the owner's association or developers of the, I'm assuming, gated community.
Old Feb 10, 2009 | 01:25 PM
alvinh
Honda has replaced the unit and is still trying to determine the cause of the problem. I spoken with Homelink, and they suggest an outside source of interference. I've removed my EZpass and my blue-tooth connected cell phone. Nothing works. Any suggestion as to what might be a source of interference?
msk
Sep 23, 2017 05:13 PM
edwardeb
Jan 31, 2009 10:19 AM
HawkeyePierce
Jan 2, 2009 08:19 PM
mysterysmoker
Aug 9, 2008 01:54 AM
acordo1
Nov 14, 2007 09:21 AM
