HONDA ACCORD 2000 EX A/C works on and off
Old Jun 18, 2009 | 02:44 PM
debigram123's Avatar
Default HONDA ACCORD 2000 EX A/C works on and off
My A/C began acting up a couple of weeks ago. It will blow cold air but if you hit the "fresh air" switch. It cuts the compressor out. When it works it is ICE cold problem it it keeps shutting off. When it shuts off, I can turn power on and off and it comes right back on.. but only for a couple of minutes at a time.. Any suggestions would be greatly appreciated..
Old Jun 19, 2009 | 11:49 AM
Problem description suggests an intermittent AC on/off switch. When you stab the Fresh Air/Recirculate button you may cause the switch to open. I would remove trim and access the switch. you should be able to create a jumper short to simulate the closed switch to "fix" the problem temporarily. If that works, then switch must be repaired or replaced.
You should purchase a shop manual or check autozone.com for info on your model.
Old May 30, 2011 | 09:26 PM
gapeach76's Avatar
I need to know where the ac switch is located on a 2000 accord se 4 cylinder
jlpatterson
Dec 9, 2013 06:25 PM
Jul 29, 2013 12:55 PM
bustedhonda
Jun 11, 2009 04:53 PM
DA KID RYU
May 14, 2008 09:57 AM
cuatro201821
Apr 1, 2008 09:06 AM
