Honda accord 2000 start up issue
Old May 31, 2011 | 05:06 PM
nufftalon's Avatar
Default Honda accord 2000 start up issue
Recently had transmission changed. I had a tune up about a year ago. I tried starting car this morning nothing. Check fuses they were fine, spark plug had spark. I spray carb spray and it worked like a charm I was low on gas but it wasnt on E. I drove it to work it was fine turned it off started it again and it started up. So I don't think its a leak or anything. I guess my question is if it does need a tune up do you think it can last until this friday when I would be able to take it in to get a tune up if thats even necessary?
Old May 31, 2011 | 08:56 PM
When you say "nothing",,,,,what does that mean. starter turns over but the car does not start or nothing from the starter?
If the starter is turning.....then get in a habit of turning the key to on/pos II and watch the cel. Once the cel goes off, try to start the car.
If not, have the system tested, battery, cables. starter, ect.....
Old May 31, 2011 | 09:54 PM
nufftalon's Avatar
sorry when I turned the key it would make the noise like it was trying to start up but that's it. I never had this problem before ill try what you recommend though and see what happens thanks
Old Jun 1, 2011 | 06:40 PM
So it sounds like the starter was spinning, I think.
Get in the habit of turning the car to ON/Pos II and watch the lights on the dash...mainly the CEL
Old Jun 16, 2011 | 09:05 PM
nufftalon's Avatar
thanks no problems since then........had a set back with funds but gonna go for a tune up tomorrow. What are some of the things that should be taken care of by the mechanic on the tune up? I need to make sure that the mechanic I go to handles all this he was referred to me by a neighbor that fixes cars mans been in business since 85'. Thanks again.
Old Jun 16, 2011 | 11:53 PM
nufftalon's Avatar
here is the services the auto place offers for a tune up
tune up
Old Jun 17, 2011 | 12:01 AM
Tek310's Avatar
spark plugs, spark plug wires, fuel filter, distributor cap and rotor, oil change, air filter, egr port cleaning, transmission fluid/filter drain and refill, thermostat replacement, radiator flush, fuel treatment, pcv valve.
that would be the A+ tune up
recommended
-fuel filter
-plugs
-plug wires
-cap and rotor
-oil change
-fuel treatment
-air filter
here is the write up on egr port cleaning
http://www.youtube.com/watch?v=d8N-SE047VY&feature=fvsr
may be a tad bit different for the 98-02 accords.
Old Jun 17, 2011 | 12:10 AM
nufftalon's Avatar
awesome thanks for the info I appreciate it.
whats a reasonable price for a tune up if all goes well and theres no major problems discovered for long island ny.
Honda Accord 4 cylinder 1998 Coupe
Tony1M
Nov 6, 2023 08:29 PM
bushcal
Aug 8, 2012 01:56 PM
gasface11
Jul 11, 2012 12:33 PM
kubafle
Aug 17, 2010 06:51 AM
slammed
Mar 8, 2010 07:46 PM
