Honda accord 2000 start up issue
Recently had transmission changed. I had a tune up about a year ago. I tried starting car this morning nothing. Check fuses they were fine, spark plug had spark. I spray carb spray and it worked like a charm I was low on gas but it wasnt on E. I drove it to work it was fine turned it off started it again and it started up. So I don't think its a leak or anything. I guess my question is if it does need a tune up do you think it can last until this friday when I would be able to take it in to get a tune up if thats even necessary?
When you say "nothing",,,,,what does that mean. starter turns over but the car does not start or nothing from the starter?
If the starter is turning.....then get in a habit of turning the key to on/pos II and watch the cel. Once the cel goes off, try to start the car.
If not, have the system tested, battery, cables. starter, ect.....
thanks no problems since then........had a set back with funds but gonna go for a tune up tomorrow. What are some of the things that should be taken care of by the mechanic on the tune up? I need to make sure that the mechanic I go to handles all this he was referred to me by a neighbor that fixes cars mans been in business since 85'. Thanks again.
spark plugs, spark plug wires, fuel filter, distributor cap and rotor, oil change, air filter, egr port cleaning, transmission fluid/filter drain and refill, thermostat replacement, radiator flush, fuel treatment, pcv valve.
that would be the A+ tune up
recommended
-fuel filter
-plugs
-plug wires
-cap and rotor
-oil change
-fuel treatment
-air filter
here is the write up on egr port cleaning
http://www.youtube.com/watch?v=d8N-SE047VY&feature=fvsr
may be a tad bit different for the 98-02 accords.
recommended
-fuel filter
-plugs
-plug wires
-cap and rotor
-oil change
-fuel treatment
-air filter
awesome thanks for the info I appreciate it.
whats a reasonable price for a tune up if all goes well and theres no major problems discovered for long island ny.
Honda Accord 4 cylinder 1998 Coupe
bushcal
Aug 8, 2012 01:56 PM
gasface11
Jul 11, 2012 12:33 PM
kubafle
Aug 17, 2010 06:51 AM
