Honda Accord 2001 brake light
Old Feb 28, 2012 | 06:47 PM
khbarry's Avatar
Default Honda Accord 2001 brake light
Is it true if the brake light switch does not work that the shifter will not allow you to move from Park without using the release switch? I think I have a bad switch, but the shifter does work. I do not have any brake lights or center high mount stop light, but the fuse and bulbs appear to be OK.
Old Feb 28, 2012 | 08:16 PM
skramer's Avatar
The brake light switch was unplugged on my daughter's '93 Accord and it would not shift out of park without the release switch. I don't know about the newer generations, my '99 is a MT.
Old Feb 29, 2012 | 06:56 AM
It's still true with new auto-trans cars. Federal law.
So that probably means KHBarry's brake-pedal switch is OK, but the circuit it broken somewhere "downstream" before the brake lights.
Old Feb 29, 2012 | 04:51 PM
khbarry's Avatar
Thank you for your replies.
Since then I did do an ohmeter check on the switch and it does appear to be working. Is there only one fuse, the "Stop" fuse, 20 amp, in this circuit. I had a mechanic say that the next place to check is in the turn signal, steering column area. Does that sound feasible?
Old Feb 29, 2012 | 08:56 PM
Please check or replace the bulbs (bulbs are cheap). Is the "warning" on for the brake lamp?...then there are two fuses involved in the brakes.
Jmblec2
May 16, 2012 04:57 PM
victorywhity
Mar 24, 2011 09:37 PM
jwk8199
Sep 23, 2010 03:47 PM
cecoen
Aug 21, 2009 07:59 PM
