Honda Accord 2001 brake light
Is it true if the brake light switch does not work that the shifter will not allow you to move from Park without using the release switch? I think I have a bad switch, but the shifter does work. I do not have any brake lights or center high mount stop light, but the fuse and bulbs appear to be OK.
Thank you for your replies.
Since then I did do an ohmeter check on the switch and it does appear to be working. Is there only one fuse, the "Stop" fuse, 20 amp, in this circuit. I had a mechanic say that the next place to check is in the turn signal, steering column area. Does that sound feasible?
victorywhity
Mar 24, 2011 09:37 PM
cecoen
Aug 21, 2009 07:59 PM
wize_n
Oct 10, 2008 06:49 AM
