honda accord ex 1999
Old Apr 28, 2012 | 01:11 PM
ventura7474's Avatar
Default honda accord ex 1999
Hi i have problem no dash lights. i inspect both multiplex units relays, fuses, they are ok. i took this car without radio dashlight was working but
when original radio was installed again, dashlight did not work at all need help. thank you.
Old Apr 28, 2012 | 01:25 PM
It's best not to append to an existing thread. It's confusing to potential repliers.
You need a wiring diagram of instrument panel circuitry so you can identify power supply wire/s to the dash lights. Remove instrument panel and disconnect. Check power supply wires for 12V w/ keyswitch On. If no power, then either damaged wiring or you missed a fuse. If you have power to the dash connector, then damaged instrument panel or all the bulbs are bad (unlikely).
If you don't have a manual, you are wasting time. Check Online Manuals post in DIY forum for a download. If no free download, go to ebay "automanualsource" for a $21.99 download of OEM manual.
pturnbul
May 3, 2007 02:30 PM
craigpalmer
Mar 7, 2007 02:16 PM
midway
Feb 6, 2006 10:59 AM
waikikiguy
Dec 4, 2005 10:56 PM
rogersah
Mar 22, 2005 02:56 AM
