Honda Accord problem please help
Old Apr 19, 2012 | 01:39 AM
deserthonda's Avatar
disconnect the frt exh pipe going into the cat conv and retry it ,, also chk air filter make sure that it is not totally plugged
Old Apr 19, 2012 | 06:47 AM
jayd's Avatar
Originally Posted by Tyler Joyce
That hose is just a breather hose it wouldnt make your car idle like that. It wouldnt do anything at all actually. Just keeps pressure from buildiing inside the valve cover.
I would take some sort of brake cleaner or engine cleaner and spray it everywhere there is a seam with a gasket on the engine. Everywhere. Even the spots you dont think have any problems. While the engine is running and you are doing this, if it bogs down or shuts off while you spray a certain seam then there is a vacuum leak in that seem.
going to try if the engine will stay running long enough thanks
Old Apr 19, 2012 | 06:50 AM
jayd's Avatar
we went through that and could not get the bolts off. used a big tourqe bar to try. i may take it off at the manifold.
my three thoughts are either,
fuel injectors
Clogged cat
or i am doing something wrong with the timing. (which i doubt because i did itmany times before on other cars and i did it the first time on this one and it ran fine.
superdappa
Mar 17, 2022 11:45 PM
Jae Min Chang
Sep 17, 2013 04:23 PM
phr3shaccord
Oct 18, 2011 12:00 PM
boroko
Aug 17, 2010 08:38 PM
eddyfurukawa
Feb 13, 2006 03:15 PM
