Honda issue #4080 ( the AC )
Old May 23, 2007 | 08:28 AM
maro's Avatar
Default RE: left fan (facing car) not working
I was unable to find a map to the fuse box under the dash. Which is number 4 and 8. I did not check every single fuse to see if one was dead. Maybe I should. The Fan is not getting any power. I pulled the A/C fan relay and saw there are 4 outlets. I was unsure which one was the white / blue/yellow. I will take a closer look later today as it was getting dark. Is this the correct relay (with the 4 outlets on it) . Regardless I tried a number of differenent paperclip connections, and still no fan.
thanks for help. I think I still need it.
Also, 19962dr mentioned bypassing or re-routing the computer. What does this involve?
Old May 23, 2007 | 05:59 PM
You have to look at the wires coming into the plug to figure out the colors, sometimes that may mean pulling back the covering a bit. There is also a relay for the A/C compressor next to the fan relay. Make sure that you are testing the right connection. The compressor relay will have different color wires going to the plug. I think that red is one of the colors for the compressor connection. Just make sure you are testing the right connection.
Ok, there are two tests to check test that connector to that A/C fan relay. I posted a pic below.
1. Test for battery voltage from white to body ground. Go to step 2 if you have 12V.
If no power on white, then you will have to trace the electrical problem back to the fuses. The fuse box cover(s) should have the information printed on it.
2. Jump the white and blue/yellow.
[IMG]local://upfiles/5767/5FCBD50C19904EBCAD633874AAB1C9F0.jpg[/IMG]
Old May 24, 2007 | 01:37 PM
maro's Avatar
thanks, I'll give it a go and let you know
thanks PA
tzoromski1
Oct 4, 2012 10:24 PM
Cubeman
Jul 23, 2012 12:40 PM
zZHellBlazerZz
Jun 15, 2011 10:12 AM
art vandelay
Aug 2, 2010 09:29 AM
rhinotechie
Aug 7, 2005 09:45 PM
