Hood latch busted
Old Jan 17, 2008 | 10:08 PM
jewlow
Default Hood latch busted
1989 honda accord hood latch is busted. how can i manually pop the latch?
thanks
Old Jan 17, 2008 | 10:09 PM
jewlow
Default RE: Hood latch busted
edit: latch is busted from the inside (cable snapped)...actual latch is undamaged
Old Jan 18, 2008 | 05:16 PM
I would try to access the end of the cable under the dash, connect w/ good vise grips, and pull to open. Cable may have separated from the hood release latch.
It may be possible to work from underneath the car, remove the bumper, and reach the latch. You might simply forcibly remove the grill to access the latch. It would help to find another car of your model to inspect for possible access methods.
Old Jan 19, 2008 | 07:15 PM
HondatechAV6's Avatar
if removing the bumper isn't an option for some reason you can remove the clips holding the left front fender liner in place and lower it down. then you can see the hood release cable heading to the inside of the car. work your magic(clip the cable and try and pull the wire)
bjr001
Feb 7, 2021 11:19 AM
RedLineZ_05
Oct 18, 2012 09:24 PM
Planefreak
Oct 15, 2007 12:17 PM
2002haccord
Jan 7, 2007 06:25 PM
Bullethole
Sep 11, 2006 01:04 PM
