horn help please.
Old Aug 2, 2007 | 06:20 PM
PowerAddict
Default horn help please.
I was helping a buddy figure out his horn issue on a 98 accord ex. Pretty much as it was, the horn worked when the wheel was turned, but would not work if the wheel was at the 12 o'clock position. So I figured it was the clockspring, adn I replaced it. The night I replaced the clockspring, the horn worked. But then the day after it stopped working at the 12 o'clock, and then eventualy stopped intermittently in any position.
does anyone have any other ideas?? help appreciated.
Matt
Old Aug 2, 2007 | 07:02 PM
sir_nasty's Avatar
Default RE: horn help please.
The steering column wiring has a spindle type deal with all the wires in it and that might have a connection issue.
Old Aug 3, 2007 | 12:09 AM
PowerAddict
where is this located? And will I recognize it if I see it?
Old Aug 3, 2007 | 02:22 PM
sir_nasty's Avatar
It's right behind the steering wheel, it's what keeps the wires connected to the wheel and prevents them from getting screwed up when you turn
Old Aug 3, 2007 | 03:04 PM
PowerAddict
sounds like you're talking about the clockspring (its also called the SIR coil)to me. Thats what I replaced.
I think the airbag has a contact pad in front for the horn and is not making connection????
Old Aug 3, 2007 | 10:14 PM
PowerAddict
think I found the problem.
the wire going up to the horn connector underneath the airbag pad is really loose.
Is it safe to take the pad off of the airbag? Is there a special process?
Old Aug 5, 2007 | 04:38 PM
PowerAddict
TTT
mamtsberg
Mar 17, 2010 09:15 PM
spanishpete
Jul 25, 2006 11:36 PM
chronchameleon
May 12, 2006 12:47 PM
silverstreak89
Apr 6, 2006 03:12 AM
phaders
Jan 19, 2006 12:03 AM
