How to adjust accessory belts?
Old Mar 17, 2012 | 10:06 AM
Cody_754's Avatar
Almost A Senior Member
Default How to adjust accessory belts?
How do you adjust the ac compressor and alternator belt on a 97 accord? They both came loose somehow and I can't find the belt tensioners. Please explain how to do it also, thanks!
Old Mar 17, 2012 | 10:27 AM
LS-300's Avatar
If you look at the alternator there are 3 bolts. Two facing the front of the motor the other facing the front of the car. The one facing the front of the car will be below the alt housing. You loosen the front bolt but don't remove. Then tighten the bolt facing the front of the car until proper tension is achieved. Then retighten all 3 bolts. The one belt runs both the Alt & AC.
spivieguy1
Sep 22, 2010 11:24 PM
mugenpaolo
Apr 13, 2009 09:34 PM
siciliangrl
Jan 5, 2007 09:51 PM
dtc
Aug 13, 2006 01:16 AM
genetik_freak
Apr 27, 2005 08:31 PM
