How can I bypass the Clutch
Old Oct 28, 2007 | 02:45 PM
miami honda's Avatar
Default How can I bypass the Clutch
I dunno if our 5 speeds have a clutch module but the only way I can turn my car on is by pushing it. If I press the clutch nothing happens it appears as if something died. Is there such a thing as a clutch module? Where could I find it or better yet can I by pass it so that I only tunr the key and have the car start.
[align=left] [/align]
Old Oct 28, 2007 | 04:21 PM
Default RE: How can I bypass the Clutch
There is a switch that the clutch pedal closes that allows the car to start. Its a safety feature so you don't start the car while it is in gear.
That switch is high up on the clutch pedal. You can bypass it by uplugging then jumping the two pin connector with a piece of wire or paperclip. Just make sure that you are in neutral when starting the car.
Old Oct 28, 2007 | 05:06 PM
smaglik's Avatar
its broken on my passport. need to make sure to tell people that.
ncsgoofy
Jan 9, 2007 10:15 PM
crazyb3e
Nov 13, 2006 01:55 AM
thunder_x
Oct 6, 2006 07:10 PM
tamb
Jul 21, 2006 01:05 AM
dave118811
Jun 8, 2006 02:08 AM
