How can I locate P.S. belt tension bolt on 1998 LX?
Old Apr 16, 2013 | 04:54 PM
Blackcomet94's Avatar
Default How can I locate P.S. belt tension bolt on 1998 LX?
Hello,
My fist post
I am planning to replace alternator and P.S. belts on my 1998 LX 4cyl.
I don't think that I will have a problem with the alternator belt.
However, I could not locate the bolt that can adjust P.S. belt tension. According to the diagram, I can lossen #6 and #17 bolts so I can remove the old belt.
Would someone please let me know where that particular bolt is locate.
If it doesn't exist, how can I adjust belt tension.
Regards,
Old Apr 16, 2013 | 05:11 PM
A nice pry bar/breaker bar
Old Apr 16, 2013 | 05:18 PM
Kind of like this. Doesn't show the braker bar but you'll figure that out.....just be careful. You want just enough where the belt does not make noise....too tight and bearings get worn out.
Attached Thumbnails How can I locate P.S. belt tension bolt on 1998 LX?-6th-gen-ps-tension.jpg
Old Apr 16, 2013 | 06:06 PM
Thank you
You are the man!
Look like I will need an assistant
Old Apr 16, 2013 | 06:23 PM
Get creative.....I have the ps belt tension down to a science on my 3rd gens- same "pry bar" set up on the PS. I have a nice long pry bar, place it in there, gentle push with my right shoulder, tighten the lock bolt with my left hand....done, simple right
Old Apr 18, 2013 | 03:32 PM
Thanks for your help.
BTW, I am looking for torque specification for P.S. pump as well as alternator.
Would you please point me to where can I find those info?
Is there any 6th generation accord service/ repair manual available for download?
Thanks again.
Old Apr 20, 2013 | 07:18 AM
You can get a manual for this from automanualsource - $22 for a download, $27 for a cd shipped.
PS and the lower alt bolt do not take much....~16 ft lbs. Looks like the upper bolt to alt is ~33 ft lbs.
Old Apr 21, 2013 | 04:39 PM
Got it
Thank you
Old Apr 22, 2013 | 07:41 PM
Our pleasure to help.
Strick9KS
Jul 29, 2012 07:15 PM
pancho88
Mar 20, 2012 02:22 PM
19962door
Mar 15, 2011 07:18 PM
elvis1977
Nov 18, 2010 10:03 PM
