How to change front headlights *2003 Honda Accord ex coupe*
Old May 14, 2008 | 05:34 PM
atticus27
Default How to change front headlights *2003 Honda Accord ex coupe*
I just bought some headlight bulbs and i'm not sure how to replace/change them. Does anyone know a website that teaches you step-by-step or can explain throughly? Thanks!!
Old May 14, 2008 | 05:42 PM
finch13's Avatar
Default RE: How to change front headlights *2003 Honda Accord ex coupe*
Wow. Unplug, twist, remove. Insert, twist, plug.
Old May 14, 2008 | 05:43 PM
poff1986's Avatar
4 cyl.
1- pop hood
2- go to right front headlight
3-disconnect bulb connector, (low beams are further in towards the fender, can be checked with lights on and lining up with bulb on backside of housing)
4-Twist bulb counterclockwise and remove
5-install new bulb and twist in place and install connector
6-Go to left front headlight side wheel well
7- remove the first clip in the upper right hand corner of the fenderwell liner
8-pull down fenderliner
9-using either a flash light or feel reach in towards the headlight and disconnect connector
10- remove bulb by twisting counterclockwise
11-install new bulb and connector
12-reinstall fenderliner and clip
For the v6 go to step 6 and use the same for both sides. ( cant remember you may be able to get rf on v6 the same as 4 cyl.) dont hold it against me though.
Pilot Mobbin
Jan 30, 2013 07:18 AM
jaxbud
Jan 13, 2011 09:09 AM
Sheryl S
Sep 10, 2009 09:59 AM
dwalls32
Jun 22, 2007 09:40 AM
