how to check or set a timing on 2000 accord SE
Old May 29, 2011 | 11:10 AM
noltian's Avatar
Default how to check or set a timing on 2000 accord SE
I read a manual but still not sure how to check a timing on 2000 accord SE. Well. the reason I want to check timing is that I get a poping sound and the engin jerks every 5-6 seconds on idle. I replaced the cap, rotor, spark plug to rule out. Another thing I want to try is to check a timing.
Do I need to take a cover off to find inspecion hole to see a timing mark?.
Old May 29, 2011 | 11:56 AM
Assume this is a 4cyl.
You'll need to pull the upper tb cover. Then set the crank to TDC (pointer on crank pulley) the check the cam gear marks......
joellv72496
Dec 11, 2012 07:25 PM
iluvmysh
Aug 31, 2011 08:31 PM
xp190
Apr 29, 2009 11:53 AM
ron
Oct 20, 2005 03:00 AM
