How do I deactivate the theft alarm?
Old Mar 21, 2011 | 01:16 PM
findingZzero's Avatar
Default How do I deactivate the theft alarm?
Well maintained 98 Accord EX. The alarm goes off unexpectedly (short?) usually after sitting overnight. Most times the trunk is open or about to be. How hard is this to check, fix, disable?
Old Mar 21, 2011 | 02:11 PM
I would disconnect the battery and clean all ends of both battery cables with a wire brush. I would also clean the bolts and washers holding them down. See if that helps.
Also a weak battery can cause problems for the alarm system. Have the battery/alternator/starter tested at a parts store.
Old Mar 21, 2011 | 10:13 PM
I will look into it. Thanks SuperM
lecompte51
Jul 3, 2013 01:38 AM
mglexit
Mar 15, 2012 11:53 PM
tweaked17
Jul 24, 2009 09:22 AM
prkarpi
May 30, 2009 02:58 AM
obietom
Nov 23, 2005 07:49 AM
