How to get the SES codes out of a 1995
Old Jun 1, 2008 | 09:54 PM
PhillyTurboSix's Avatar
Default How to get the SES codes out of a 1995
I have a friend with a 95 Civic 4cyl. He recently replaced the engine in the car. The SES light was on with the old engine. It's still on with the new engine (Junk yard engine with low miles). It's a 95 Civic with Vtech. I took it to Auto Zone to have the scanner put on it and that's when I found 95 and older are not ODBII readable. He said something about you have to make the SES light flash the codes out. Any help on this would be great! Thanks!
Old Jun 1, 2008 | 11:10 PM
HondaPhyco's Avatar
Default RE: How to get the SES codes out of a 1995
You have to jumper the connection, i have no idea about civics but there should be a wire under the glove box, with 2 pins. stick a paperclip in the whole so you connect them, them turn the key to the one position, the codes should flash, long pause is like 1.........2.........3........ then short go 1..2..3. if you get 1 long and 3 short thats a code 13.
to reset the light, you have to do much more, there is a write up somewhere, because i used it.
argarcia86
Jul 2, 2012 06:46 PM
narshank
Sep 3, 2011 06:54 PM
ACCORDingtothestreets
Oct 30, 2009 01:53 AM
finch13
44
Apr 21, 2008 11:45 PM
isenegger
Jan 19, 2008 08:15 AM
