How much back pressure (blow-by) is normal?
Old May 2, 2013 | 05:07 AM
jsatx's Avatar
Default How much back pressure (blow-by) is normal?
It's a '92 2.2L with 166,000 miles. It runs smooth at all rpms and doesn"t
smoke. When I remove oil fill cap on valve cover with the engine idling. I get
a blast of hot air spewing drops of oil coming out. Is this normal? Does it indicate problems or future problems wit valves or rings?
jsatx '92 honda accord LX 2.2L automatic
Old May 2, 2013 | 08:44 AM
Dr. Drivability's Avatar
replace your PCV valve. FWIW, back pressure and blow-by are 2 different things.
as far as it being "normal", i wouldn't say it's abnormal.
Old May 2, 2013 | 12:21 PM
You should have suction into engine at idle, not pressure, so PCV could be faulty as Dr. D suggested.
If you put a piece of paper over the oil fill inlet, it should suck closed. It could be that engine has aged to point where there is enough blowby past rings to cause a net positive pressure.
Worst symptom of this is oil/blowby is pulled into throttle duct PCV air inlet and additional oil consumption. Some have placed an oil trip in the air inlet to reduce amount of oil pulled into engine. All engines occasionally have positive crankcase pressure (under throttle) and pull oil vapor into throttle duct.
Old May 2, 2013 | 09:28 PM
jsatx's Avatar
Thanks Dr.D and TexasHonda.
RobinsonRicer
Dec 22, 2013 08:42 AM
Sadus
Sep 6, 2011 11:29 PM
NICK63
Nov 2, 2009 11:57 AM
piconrule
Jul 24, 2009 02:38 PM
kendo
Nov 3, 2008 10:37 AM
